staxx thank you for the answer. so does it completely disengage? or like a standard viscous; and run at a low % of eng. rpm. has any one retro fitted it to older engs.? my e9 runs too cool most of the time I thought I had a bad thermostat but changed both and no improvement. guess I might have to find a set of shutters
Would not work on a older truck , needs to be v-macIII or newer 97-98 newer . this needs a computer to monitor and run correctly. But there is a two stage air on off fan that would work very well for you.And no the electronic fan will not completely disengage .
