I'm new to all this and recently bought a 1996 CL700 logger and have transmission (18 spd MaxiTorque) problems. It often won't go into 3/4 (7/8) or will pop out. I know of a wrecked 2000 CH613 (highway truck I believe) from which I can get a very reasonably priced transmission. Both sticks look the same but does anyone know if it would be an exact fit (just bolt it right in)? Also, would there be any computer issues? Thank you.
https://www.bigmacktrucks.com/topic/33419-transmission-swap-for-1996-cl700-logger/
I thought that the CH613 had an 18 spd as well (same stick as mine with a range selector and splitter). Is there a way to know for sure off the VIN? (last 6 digits are 111319).
could be a13 or an 18, look a the tag on the right side of the transmission, if it's missing use the vin, but it may have been swaped out at one time, the tag is your best bet.
Stick with what you have and rebuild it. You'll be money ahead to put the coin into it and do it right. The one in the CH could be just as bad too. CL's also have a shifter relocator on them because the tranny is so much further ahead. I would rebuild what you have or get a mack pedigree remack
