My 97 Mack CH613 shuts down while at idle and going down road. I was told it's the ECM. This is a mechanical engine so there is no ECM on the motor only in the cab on the passenger side behind the kick panel. Just for diagnosing purposes I got a ECM out of another truck put hooked it up in my truck it runs until I turn the key back. It also will take the truck down the street it does not have full engine power and it's smokes but it does not shut off so I've came up with it's the ECM!!! Any suggestions? PLEASE HELP!!!
https://www.bigmacktrucks.com/topic/33420-engine-shuts-down/
Need to buy a new ECM and have it programmed find a used good module same as your old one or have your old one rebuilt.
thanks for your reply I want to make sure I'm understanding you correctly when you say module you mean the ECM correct?
https://www.bigmacktrucks.com/topic/33420-engine-shuts-down/#findComment-215866
sorry just seen this. what i would do first is remove the tachometer sensor clean it and put back in. what it sounds like is happening is the tach sensor/tach issue may be putting the ECM in Derate mode, it is doing it because it senses the tach not working correct.
https://www.bigmacktrucks.com/topic/33420-engine-shuts-down/#findComment-216178
Thanks for the help where is the tach sensor located? Thank
https://www.bigmacktrucks.com/topic/33420-engine-shuts-down/#findComment-216468
I believe on this model it is still going to be screwed into the engine bell, you will see a pigtail plug going to it, if you unplug the plug you can screw the sensor out of the engine bell. when you remove clean the magnet and screw back in. look at the wiring where it goes into the sensor to see if look freyed or broken. this sensor will look identical to the speedo sensor which is located on the output of the transmission, and on some models was even the same part number. the flywheel serves as the toning ring for this sensor. a year or so after this they moved this sensor to the face of the engine bell rather than on the outside diameter of the engine bell. hope this helps..
https://www.bigmacktrucks.com/topic/33420-engine-shuts-down/#findComment-216845
This the same sensor that screws in at the fly wheel?
https://www.bigmacktrucks.com/topic/33420-engine-shuts-down/#findComment-216895
If the ECM wasn't sending a good signal to your econovance your engine timing would not work correctly , so yes
Hello Staxx thanks for all the help the truck is back running great does not cut off since the new ECM has be programmed and out in. Now I have a situation with my head light since the new ECM is in all the clearance lights comes on but my headlights does not come on. They will work when you press the flash to pass button so I know the lights work. I put a fuse in fuse 16 spot #16 the lights comes on but when I turn all the lights off with switch the head lights stays on. What could cause this?
https://www.bigmacktrucks.com/topic/33420-engine-shuts-down/#findComment-216897
Sounds like a bad high beam switch
Matt
https://www.bigmacktrucks.com/topic/33420-engine-shuts-down/#findComment-216898
Day time running lite switch actives headlites anytime parking brake is released and fuse 16 is in.
Ok thanks so what do you recommend to get the lights to work when I push the button in on dash to turn them on? Is there a fuse for the lights if so what # fuse?
https://www.bigmacktrucks.com/topic/33420-engine-shuts-down/#findComment-217026
  • 5 years later...
O8 mack chu  mp8 engine  yesterday  lost all  power and truck shut completely  down, all fluids  are full, dash shows circle with  x,it'll  start up runs for minute half then it's  like fuel  shuts  of,mediate  shut off,no spit and rudder can someone  help  me  out,in last 3 weeks  replaced  transmission, front rear end and exhaust baked and clean  someone  help  me please!!!!
https://www.bigmacktrucks.com/topic/33420-engine-shuts-down/#findComment-429297
https://www.bigmacktrucks.com/topic/33420-engine-shuts-down/#findComment-429339
