Bro Its Either shutting down on High coolant temp Low oil level low oil pressure  Low coolant level usually will not shut the engine down  ! Low oil level Sum times depends on programming!  I would Lean heavy towards replacing  oil preasure sensor! These are or have be a pain in the as from time to time!
By the way create your own post  for this you will get better press! More guys alot smarter than me ! will respond to a new post!
Edited by fjh
