Is that with the fiber coupling or the old tang drive?
If the tang drive if you line up the hole and pin it should be close if it was right before.
If the fiber coupling the half tooth missing with the pin should do the same thing. I have seen where on both styles when putting the coupling on the shaft of the pump you can miss the key way & on the fiber coupling style if you miss the half tooth the pump will not go all the way to the block it will like about 1/4" and seen people pull it up with the bolts and it will make another half tooth in the fiber coupling and if I remember correctly the timming will be out about 12-15 degrees.
