I have a old oshkosh truck and within the last couple weeks upon starting first thing sometimes it will build air pressure and sometimes it won't.
On the times it won't if I go out and rev up the engine by hand it will start to build then be fine.
Not sure where to start checking, was told maybe check valves need to be replaced??
Any ideas would be appreaciated.
Thank you.
Kurt
Check The Line That Goes From The Compressor To The Dryer, Could Have A Hole In it.
The Easiest Way To Find A Leak Is To, Unhook The Line From The Compressor And Rig You Up Some Fittings And Hook Your Shop Air UP To The Line.
This Way You Can Hear Everything Without The Engine Running.
Works Like A Charm
