Why can't you cut the filter and see if you can put in a straight pipe, maybe drill a couple holes so the sensors see pressure but all the sute goes out the pipe. Let it do it job just restrict the crap going into the filter?
I am no expert on this but I remember the OEs designing the system to be "tamper proof". The computer senses some backpressure so if one removes the filter it will throw a code and possible derate because the BP is too low. Again, no expert but this is what I remember from my "working days".
Ken
https://www.bigmacktrucks.com/topic/33728-07-vs-o8/#findComment-220734
I understand yet you would think there's a way to trick the computer. That filter things a challenge. I've been looking at 2007 and older cause you could change the eng and just do what you have to. 08s and newer will always have a filter and the computer systems are harder to fool. My opp.
https://www.bigmacktrucks.com/topic/33728-07-vs-o8/#findComment-220752
