I try to grease my truck at least once a week, and I always just put 10-15 shots in the trunnion. I've heard that you're supposed to jack the truck up where the weight is off of the springs, but I never do that. I may be messing up, I'm not sure.
Jake
Like they said grease is cheap, I did my dump trucks weekly, road trucks every two or three weeks unless the weather was funky. Bad weather or I was hauling the dump trailer off road then weekly.
Yes, you are supposed to jack the rear of the truck up via the frame, this takes the static load off the bushing & will allow the grease to get where it is needed most, THE BOTTOM. Highly recommend a EP or Extreme Pressure grease, as it will continue to lubricate the bushing to shaft surface even under extreme loading.
Richard Mark
Owner / Master Model Maker
Industrial Model Design
Ap40rocktruck
  • 8 years later...
Your supposed to jack up your truck when greasing trunnions. Need to take the weight off, then grease till a little comes out. Most people don’t know this but it is the right way. I don’t know if NOT doing it will make much of a difference but when you buy a 190k dump truck, yea I’m gonna do it the right way!
