Good thing you got those injectors out of there Rob.
Next thing you know, a piston would have a hole melted through it.
AGREE! I'm working at the airport this weekend so I won't get to be in the shop but tomorrow evening I'm going to run a compression check, (like I planned a few months ago) while the nozzels are out.
I also pulled the lines from the pump and am going to look for a new set as these are really corroded in places. I'm thinking the structural integrity may be compromised from the pitted rust at the retention nuts, and routing/mounting brackets.
As I was told, this truck had sat for 17 years in a yard before being worked with by the prior owner.
Despite these minor "setbacks", it does have the foundation for being a good truck.
Thanks,
