I jacked up the front and found some play in the steering gear box, kingpins drive shaft drag link seem fine, is that little play inside the box enough to do that, and can it be adjusted, I see something above the grease fitting, do I just turn that?
https://www.bigmacktrucks.com/topic/33811-truck-has-a-bad-vibration/
a bad "vibration" adjusting steering box wont fix a vibration; just slop in the wheel.when does this vibration occur? is it speed sensitive or when turning or after hitting a bump? need more info
