I jacked up the front and found some play in the steering gear box, kingpins drive shaft drag link seem fine, is that little play inside the box enough to do that, and can it be adjusted, I see something above the grease fitting, do I just turn that?
https://www.bigmacktrucks.com/topic/33812-truck-has-a-bad-vibration/
Don't tighten up your gearbox, if your having a vibration its more than likely a balance issue. What kind of vibration, thru the steering wheel, feel it thru the seat?
It felt like the drive shaft, but everything is tight and normal. Sometimes the vibes come and go. It did seem to start around the time of the accident. I have some play in my tie rods that connect the wheels together too, that with play inside the box I guess is my problem? The thing of it though is my steering wheel still stays sstraight if I let go, so that's the mystery to me.
Thanks for the responses. 2stacksuperdog was close, the pinion on the back of my transmission has a bad bearing? I was about to take the drive shaft off and go through the gears to see if it was inside there, but as I was going on my first bolt, I noticed the pinion had lots of slop in it, and the seal is bad too, (truck leaks everything, everywhere) So does anyone know how much this project will suck? I noticed four bolts going around the pinion, is it as simple as taking the yoke off and pulling the plate off to get the bear(s) replaced? or does the entire back half with all the counter shaft bearings and stuff come off too? estimated time frame? Its a Spicer 10 speed transmission as well (Spicer SD-PS-10) and I cant find any pictures of the back half taken off, so anyone that can tell me anything, please don't hold out. Thanks
Most of the time its just the back bearing since it gets less oil, I just swapped the one in my 9 speed. No big deal really you don't even have to pull the output shaft if it's just the back bearing, just pop the yoke off, pull the speedo housing and pull the back bearing, re install new bearing, speedo housing gasket and output seal, yoke and drive line.
