Yes Kyle the trim code for each injector needs to be programmed in the ECM, also a learned data reset should be done. Injector torque procedure is 15 FT pounds + 180 degrees then loosen to 7 to 11 FT pounds retorque to 15 +90 degrees. MP7 rocker bolts 44 FT pounds + 100 degrees. MP8 rocker bolts the 12 small bolts are 18 FT pounds +120 degrees, the big bolt is 44 ft pounds + 120 degrees. Hope this helps RM.
