Got a few questions for the trans specialists. I have a B65 with a 10sp unishift and the spliter valve is broken and also missing the shift knob cover. Is the operation of the factory air spliter the same as the range valve on a roadranger. I have a few of those and would be an easy conversion to mount on the stick. Next question- if I can't fix it I have a TRD-72 from another truck. I have heard that it is a 9speed and then the wiki says it is a ten speed. It also has the linkage for the auxilliary box on the outside of the box. My TRD-67 duplex is all internal. Any help is appreciated.
https://www.bigmacktrucks.com/topic/34324-trans-questions/
Any air valve should trigger the splitter, like Superdog said. It just has to be plumbed in properly, or else it might work backward!
A TRD-72 SHOULD be a 10-speed Duplex, direct drive. That is, 5th gear should be direct (1:1).
For a 9-speed, which is an overdrive model, it SHOULD be a TRD-720. The "0" generally means high gear is overdrive.
But, I have heard folks argue over whether they had a 9 or 10. Every 9-speed I ever saw was an overdrive. But, hey! We ARE talking about Mack here! Anything is possible!
The "72" is the basic 5-speed box. It could be coupled with a 2-speed rear section for a Duplex (TRD), a 3-speed rear section for a Triplex (TRT), or a 4-speed rear section for a Quadruplex (TRQ).
There are also variations on the basic numbers, indicating different gear ratios and torque capabilities (like a TRQ-720, TRQ-7210, or TRQ-7220, indicating 3 different versions of a Quadruplex).
Direct drive setups typically have as many gears as it appears (5 X 3 = 15 or 5 X 4 = 20). But, when you add the overdrive 5th gear, some of the combinations are duplicated, so they discount those (5 X 3 = 13 or 5 X 4 = 18, where a couple of the gear ratios are essentially the same). On an 18-speed, for instance, LO-SPLIT 5th is essentially the same as DIRECT 4th, and DIRECT 5th is essentially the same as HI-SPLIT 4th, So, those two don't really count. They're there...I've used 'em. You just need to not down-shift or "nothing-shift" by accident!
Nice thing about the TRQ-720 overdrive Quadruplex (or equivalent TRT-720 Triplex) is that you get 2 overdrives (HI-SPLIT 4th and HI-SPLIT 5th)!
Enough jibberish? Sorry! Here are some shift plates. The 10-speed and 15-speed shown are DIRECT models. The 18 is an OVERDRIVE model.
post-11199-0-76317400-1390334910_thumb.j
https://www.bigmacktrucks.com/topic/34324-trans-questions/#findComment-227953
