Hello,
I am getting a stream of water and some steam coming out of the valve cover breather pipe on my CH613 with E7 Vmac non-etec engine. I am also looking coolant/water out of the reservoir. The vehicle has not overheated.The intensity increases as I rev the engine.
I will appreciate any help as to what may be causing this issue.
Thank you
OO
post-11159-0-30588000-1391520196_thumb.j
post-11159-0-20809600-1391520197_thumb.j
Turn it off!
shut it down or open your wallet wider! crankshafts and water don't do well together. what isn't coming out the draft tube is going in the oil pan! get it in the shop now!
Guys,
thanks for the response, but I turned it off prior to asking the question. The heads have been pulled, and they are not leaking or cracked. The water out of the breather is quite cold, so I do not know if this means anything or not. The oil in the sump does not appear to be contaminated.
Thank you
OO
Do the valve covers and/or oil fill cap have a grey sludge like substance on them? If so you have a coolant leak into the engine. Usual culprit is leaking past liners because of an eroded counter bore ledge or leaking core hole plugs in the heads. Before you removed the heads you should have pressured the cooling system, removed the oil pan and valve covers to find out where the coolant was coming from.
I'd still pull the oil pan and look for signs of leaking liners.
Good luck
The culprit appears to be leaking core hole plugs in one of the cylinder heads. The two heads were removed, the oil was changed, and the heads were re-installed. Upon starting the engine, one of the heads had some water contamination. The other one looked normal.
Thanks Turckster..
OO
