At the fan switch you have wire from temp switch and high pressure switch. Disconnect high pressure wire. This will be better than removing belt. It is to kick fan on to reduce compressed head pressure. Take wire off and that will eliminate switch if faulty
To fan solenoid should have wire from temp sender in block, and wire from high pressure A/C line. Check continuity on wire from temp sensor to solenoid it should be easy to get to. then disconnect other wire. See if problem persists. Not saying that it is problem, but it eliminates it
