2001 etech motor problem
Go to solution Solved by Kyle 537,
have a 2001 mack rd dump truck with the e7 motor has the eup's. motor was running fine then the next day sitting out in the cold was started and it started to run rough. blowing white smoke. changed first 3 injectors same problem all 3 first cylinders 12 and 3 are cold out exhaust manifold. tried another computer same thing, disconnected jake brake too. the smoke is fuel coming out exhaust. but ran perfect the day before?
https://www.bigmacktrucks.com/topic/34668-2001-etech-motor-problem/
