We've recently tried to hook up to an OBD II connector with our bendix software and weren't able to communicate. Called Mack and was told to unplug the 16 pin OBD II connector and plug in a 9 pin connector to use the bendix software. About 12" up the harness from the 16 pin OBD II is a blue connector (behind the dash cluster). Harness Part # 21834218 plugs into the chassis side of the blue connector and has the 9 pin circle connector which eliminates the 16 pin connector for Bendix.
Seems like good info to share.
https://www.bigmacktrucks.com/topic/34823-obd-ii-and-bendix/
