if its not the linkage it is corrosion on the pin and peddle (Steel & Aluminum alloy), if you cant budge it may be time for a new one you can soak it with PB Blaster or your favorite juice but after that replace it don't know of many success stories with that kind of corrosion, without welding on a nut or heating, but that assembly you cant do it.
Some boat guys I know say vinegar works, I have never tried that. I have had better luck just replacing those kind of parts.
If it was a head or manifold I would try the heat method welding on a nut to a stud.
Robert
https://www.bigmacktrucks.com/topic/34869-stuck-gas-pedal/#findComment-235174
Hell Watts has em in stock, I put a new one in mine just so the MACK lettering was crisp and clean. But I'm a little CDO, that's OCD alphabetically, the way it should be.
https://www.bigmacktrucks.com/topic/34869-stuck-gas-pedal/#findComment-236479
