  • 4 weeks later...
When an air compressor purges and looses air in the secondary tank you have 2 bad check valves. A bad check valve in the air dryer discharge and a bad check valve at the secondary tank inlet. When an air dryer purges, the air dryer discharge check valve protects the wet tank from loosing air psi since the air gov. signal line is plumbed into the wet tank. The wet tank supplies the primary and secondary and both have a one way check valve at the inlets.
https://www.bigmacktrucks.com/topic/34952-air-problem/#findComment-240673
