I've seen people change the heater covers over to the RD style only because new superliner covers are not available. My question is can you just change the cover or do you have to change the whole heater box?
https://www.bigmacktrucks.com/topic/35015-superliner-heater-cover/
If you log on to Red Dot , a air conditioner manufacter ,they have a mack section that lists replacement parts and part numbers. The only problem ia that you have to buy from a authorized dealer. I have a 1986 superliner and have the round vents. They don't stock the round ones but I have seen the square ones.
To get the best COLD air, you must shut off the valve on the motor that's inline with the heater. I noticed a big difference with cooling.
I did that, and it would blow cold in the morning before the sun was up. But the a/c just couldnt keep up. I think this spring I will tint the side and back window. I just was disappointed with the results of $1600 in air conditioning parts
The RD I used to run would freeze you out. But, if the drain out the front was restricted, I wouldn't work very well. Might want to check that.
If you want to change over to the square style you should change all the heater. But the Red Dot and the Mack (round vent) heater bolts at the exact same place and plug to the truck harness with the same connector
Envoyé de mon iPhone à l'aide de Tapatalk
  • 5 years later...
On 3/14/2014 at 9:07 PM, MACKTRUCKS4 said:
The round vents are on the superliner , the other is on my 94 RD
1986 Mack RW613 Superliner.  I am looking for a New or Used Air Conditioning Cover with the three (3) Round Hole Vents.  Any idea, where I can find such?
  • 1 month later...
