I'm finding a little more oil each day after I've run the truck. I pulled the oil cooler and tested it and it's fine. The engine isn't getting any antifreeze/water in it. Where can this be coming from and what's causing it? I'd like to fix ASAP so suggestions are greatly appreciated.
https://www.bigmacktrucks.com/topic/35123-oil-migrating-into-radiator/
how did you test the cooler from the oil side or the water side? could be that it is only doing it at eng temp and closes up again as eng. cools. or poss.head gasket starting to fail from oil port to coolant port. I'd recheck the cooler and pressure test oil side to up to 80 psi
When I had the same problem on a F-Model with a 300 it was the oil cooler. You will have to clean out the cooling system also. I think I used dishwashing powder it was 25 years ago so I hope Glenn Akers checks in to verify. Good Luck Joe D.
