Vlad: Roadway had a ton of detroits in U-Models I believe both V-8's and V-6' The cab had to be raised because the detoit V's were not 90 degree V's like the cummins 903's. I believe they were abot 60 degrees making there profile higher. Couple this with the supercharger on top of the engine thus you needed a higher cab. I believe the Mack and Cummins V-8's would fit in the standard
U-model such as used by St. Johnsbury and watkins.
