There's a few switches that would cause the cruise to quit. Clutch and brake switches come to mind. Someone with more knowledge than myself will chime in I'm sure.
https://www.bigmacktrucks.com/topic/35273-no-cruise/#findComment-240379
.The ecm will need to be monitored with a reader. This will tell you what switches is not doing what.The VSS can be defective also.There will be two switches on the dash and a parking brake switch plus a stop light switch and a clutch switch that goes in play with it.A wiring problem as well as a module being bad can happen but only a reader will show this.
https://www.bigmacktrucks.com/topic/35273-no-cruise/#findComment-240664
  • 3 weeks later...
  • 4 weeks later...
