I have a 2005 Mack Vision has 740,000 miles At road speed the engine just cuts out and then comes back. It was missing and cutting out a couple of weeks ago put it in the shop they Found #2 and #3 unit pumps logging fault codes replaced also turbo was leaking oil out the back replaced and cleaned inter cooler. Been running truck but still cutting out also smokes bad too under low acceleration like its loading up not sure about egr related???? Also several months back broke fan clutch plug off does anyone know where I could get one besides replacing???? It also shows some weird codes like injector 13 and fuel control valve awhile back and engine management.
https://www.bigmacktrucks.com/topic/35280-mack-vision-cutting-out/
