Looking for an online source for this the rubber ones that go in the round tube that the air bags sit on. The truck I just bought they don't look the greatest figure before it needs to earn money might as well fix it now. Also if there is an online source for the torque rod that goes on top of the axle to the X member
Thanks in advance
https://www.bigmacktrucks.com/topic/35421-neway-suspension-bushings/
I got them through my local Truck parts place.
My pins were bad. I welded them up and ground them til the new bushings fit on snug. Look at the air gap with the new bushing!!
I can try to dig into my receipts and see if I can come up with part numbers. I downloaded the Neway book online.
Seems there were two flavors of this suspension> Does your bags sit flat/horizontal or on a angle? Mine were flat. I forget the part number for the style? Have to look tonight when I get home.
A quick google search found me this. Not the same catalog, but it might get you started:
http://ww1.safholland.us/quicklit/XL-AS11428PM-en-US.pdf
Thanks Larry, I also have that stuff in plans to get over.
Everything in my R-model needs attention and spares.
The rears is not exception.
I also replaced the front pivot bushings. I have the bushing under the housing also, but could not get that apart so I left it. The front pivots were also toast so glad I got them out(was not that hard). I torched the old bushing out and installed new one using existing bolt and some lube. Pretty slick.
I had it all blasted/clean/painted and easy before I did the stretch, but didn't do it. I waited til it was all together? I'm not too smart sometimes?
There should be a tag on that crossbar with the actual part number/style. I'm thinking mine was "ARD sumthing"
I dealt the Cross Truck parts in Canton, Ohio.
http://crosstruck.com/
Do you have a local place?
