don't expect a dynatard to do much except change the sound of the exhaust. with 80,000 load it equates to throwing a small block chevy out behind you on a chain. ok its not that bad but close what a mack dynatard does in most cases is, it keeps you from going any faster
https://www.bigmacktrucks.com/topic/35849-dynatard-settings/#findComment-246757
  • Solution
mort how heavy are you running? if you are used to a cummins you will never be happy with the dynatard. however if you are used to a 3406 b model cat with the first pac brake then its almost close
https://www.bigmacktrucks.com/topic/35849-dynatard-settings/#findComment-246763
