Hi guys,
I had my 1986 R in the field the other day idled up to around 1,000 rpm's using the air to run an impact wrench. All the sudden out of the blue the engine started pecking, I immediately shut it down checked the oil all good. Eased it home and with my high tech steel rod chased the sound to the valve train. Pulled the covers off found a dynatard solenoid loose and stripped out, replaced the front rocker shaft and solenoid ran the complete overhead. Didn't help at all, with engine running i loosened each injector line one at a time the noise never stopped which leads me to believe the noise is in the top. All valve adjustments look the same so I don't suspect a tappet problem.
Please help, harvest starts next week got to have a dump truck...
https://www.bigmacktrucks.com/topic/35955-4-valve-e6-350-wood-pecker/
