No air coming from compressor
Bigh361
Hey guys i need some help i have a 2002 e7 460 my truck is not building air up i took the hose off that goes to the dryer it and there is not any air coming out could it be a bad compressor someone had told me to put a new govenor so i did but still no air
The best way to check your compressor is to remove the inlet and discharge hoses from the compressor head and feel the air. If still no air pumping from the outlet check that the fitting isn't plugged with carbon, if the fitting is clear feel the inlet if no air is moving there the drive coupler has failed. If it feels like more air is being pushed out of the inlet than being drawn in the unloader in the head is stuck open.
Edited by Macktech689
