So I set up an RSS feed to let me know about anything Mack being offered on Kijiji here in Ontario. This morning I spied a fully restored B-30 tractor at an asking price of $50,000 CAD ($45,896 USD). It is located near London, Ontario.
Nice looking truck but I am more curious about the price tag. Is $50,000 anywhere near a fair price? I am having challenges envisioning how someone could invest that much in a restoration unless there is $10,000 or $15,000 in there for, "Look, it is all ready for you to hit the road and show off". What would the price tag have been on this truck when new in 1955?
post-18165-0-10418400-1402483071_thumb.jpost-18165-0-16228800-1402484058_thumb.jpost-18165-0-29719800-1402484065_thumb.j
Best regards, Dennis
It's only worth what someone's willing to pay for it....
Very few B30 gassers around and it looks good. But I agree with J_martell, it depends on how bad someone wants it. Paul
im thinkin 7500-8000 brand new. like they said, all in the eye of the beer holder. front wheels might come off the ground with that one someone has the fifth wheel centered on the rear axle.
Good catch there, Maddog13407. I thought it was just my eyes playing tricks on me (they don't work so well anymore). Seems odd that someone would install the fifth wheel incorrectly on any truck never mind a restoration.
You can very easily put that kind of money into a truck,or many times that...Ask the guy's who drop them off at restoration shops and pick them up in a few years :twothumbsup:
Thanks for that, Bigdogtrucker. I'm doing a bit of crash course in old Macks and getting an idea of values is part of that. I have been wanting a '50's era truck for a long time to go along my interest in John Deere crawler's and wheeled ag tractors of that era. I never really expected to get a Mack - figured only a Chev or maybe a Ford would be affordable on my limited budget. I feeling a bit like I've won a lottery ... and that I have some learning to do.
I have a Truck Blue Book it lists a 1957 Mack B- 30 Model Tractor GCW 35,000 lbs. 330 cu.in. engine weight 7050 lbs. factory price of $5945.00 Joe D.
Interesting info, Joe. That cab and chassis weight is very useful as I am having some fun finding a way to get my B-30 home without breaking the bank. If I remove the dump body before moving, the truck will weigh less than the crawler I hauled home with my brother's 7 ton goose neck and my RAM 2500 the other week. I'll just have to make two trips but it's only 60 miles, or so.
The loaded weights are getting a bit confusing though. From B-30 specs in the Wiki, it appears that the B-30P would have a GVWR of around 25,000 lbs. My truck has an old sticker on the driver's door reporting Registered GVW at 32,000 lbs, which is just 3,000 lbs less than the GCW of 35,000 lbs you note for the B-30T. I think GVWR and GCW are synonymous, right? Maybe in bygone days, the truck licensing depended only on how much license one was willing to buy without too much regard for the manufacturer's rated capacities?
The gvwr is total gross I believe.....tare weight + load.... Your only concern for transport should be the tare...that is, what it weighs unladen.....
I only mention this because my tare weight is close to what your talking about on your B, and my granite triaxle roll off HAS to be heavier than a b model dump empty....maybe I mistaken thought....hell, I've been wrong before, I'll be wrong again :)
Good stuff Joe. My "guess" must have had ALL the options!
Nothing better than original information, brochures or parts books to get the straight scoop.
If the truck is a B-30P it was manufactured as a platform chassis single axle straight truck witha GVW of 21-24,000 lbs. The B-30 T is a tractor model with GCW of 35,000lbs. GVW= gross vehicle weight. GCW = gross combined weight of tractor,trailer and load. Joe D.
I bought a few of these old TruckBlue books for $1.00 apiece. Lots of interesting reading. Jim it does not list any options for the B-30 in 1957 but does in later years. Their were not many options then either. Joe D.
I know my fifth wheel is only a couple inches forward of the rear axle. How far forward should it be? Not that I'll ever put a big load on it, but curious to know where anyone else puts theirs?
Going from a poor memory, but pretty sure mine is 517 axle. Maybe I'll pull my brackets and redrill them.
My trailer is only 3000# on the pin, so I'm light.
Larry, it looks like you have a gooseneck ball and not a 5th wheel. I would assume that your ball is mounted much lower to the ground than a 5th wheel would be. This would help you in your case. Just throwing it out there....
Drew
I am definitely not an expert in such matters but I think the acid test in your case would be whether your tractor ever gets light (real easy to steer) on the front end when launching up a steep grade or pushing the limits of your rig's acceleration capability. You are pulling a very light trailer for a B61 so I doubt that it matters in the least where your fifth wheel is as long as it is not behind the drive axle.
My trailer is a fifth wheel. It originally was a goose and I took the plate off the truck and made my own ball hitch. I then switched it over to a pin and put the plate back on. Much easier to hook/unhook.
I've actually seen trucks with gooseneck balls mounted behind the fifth wheel plate(giving them the option of either kind of trailer). I'm guess it matters none for overall weight rating and having too little front axle weight. My truck is still 6K lbs on the front axle empty and with no power steering..........it never gets "light" to steer LOL!!!
The pin weight is 3K lbs, but the trailer weight is 14K lbs.
It is apparent you've never driven a stock B model LOL!! Sorry, not poking fun, but there is no real acceleration capability of these trucks. 180 hp is just slow and steady :whistling:
True, never driven a B model. Growing up on the farm, Dad had an Dodge ex-dump truck with a flat head six and four speed (3 speed really because one was bull low). Farmers seemed to end up with these old dump trucks for some reason and always seemed to end up with a teeter totter of sorts in order to get enough platform to carry some kind of load. Later, after my brother and I took over the farm, we had an International Transtar 1800 ... yep, ex-dump truck. It had 5+4 and a gas engine. I know about trying to get these old trucks to move.
That ol' Dodge sure instilled a healthy respect for proper load distribution. In the Hills of Northumberland County, Ontario, where I grew up, there is no such thing as level ground - you are either going up grade or down grade. With only a 4 speed trans, there were an aweful lot of grades where you ended up in bull low to get over the top. Shift timing had to be good when going for bull low because you had to be all but stopped to get her to shift. If you ended up stopped, getting moving without the front end threatening to become airborne was quite a sobering experience. I learned to operate the brake and throttle pedals simultaneously with one foot.
