My 2011 Granite (EPA2010 MP7 405-M) shut down on idle timer on site back in the winter and wouldn't start, farted around checking things out as best I could without tools in -20c, ended up having it towed back, turned out to be a small (14 or 16 ga) "trigger" wire had rubbed through on top of the tranny....one of the few spots I couldn't get at to check.....
https://www.bigmacktrucks.com/topic/36021-wont-crank/#findComment-248910
  • 3 weeks later...
you would think trash hauler that they would put a trap door between the seats to get at that area,,
You'd figure, but no. Even if they did the tower with the pump and roll off air controls would be on top of it.....
https://www.bigmacktrucks.com/topic/36021-wont-crank/#findComment-250699
