I have a 2ve6-350 that was air to air and i want to change it to tip turbine so it will fit in my b61. i also have a complete 285 that i can get parts from. What were the differences between tip turbine 350s ( endt678?) and front mounted air to air e6-350s.
I was going to just put the 285 in the truck but i would much rather have the econdyne than maxidyne.
https://www.bigmacktrucks.com/topic/36109-2v-e6-350-change-to-tip-turbine/
I don't know that much about tip turbine. i thought they all were had water cooling. Anyway the one i has two small water pipes going into the front of it. s One thing i have been wondering about is the turbo. will the one from the e6-350 work with the tip turbine.
post-2286-0-45596300-1403383287_thumb.jp
post-2286-0-49419700-1403383315_thumb.jp
