So I finally got all the dash lights in the RD working and noticed the lightening bolt on with Code 1-7 , which should be low coolant level.After checking the coolant tank and refilling it the light still remains.I disconnected the low coolant sensor and used a wire to complete the circuit but light still on.There seems to be no voltage in the connector whatsoever and I have traced the cable and can see no damage to it.So now what?
Does this affect my engine performance?
96 rd688s
350hp
https://www.bigmacktrucks.com/topic/36180-so-now-what/
it won't derate the motor, but the shutdown indicator may come on. You can over ride the shutdown, but you may have a big problem doing that
check fuses/circuit breakers.
https://www.bigmacktrucks.com/topic/36180-so-now-what/#findComment-250910
Is the low coolant sensor float stuck? For that matter does it have a float?
https://www.bigmacktrucks.com/topic/36180-so-now-what/#findComment-250977
If this is a vmac 2 setup pin A at sensor should have 5 volts pin B should go to ground . The 5 volts comes from J1A connector at vmac module this is connector all the way on rite pin F3 at module goes to pin A at sensor this is your 5 volt wire. Good Luck .
https://www.bigmacktrucks.com/topic/36180-so-now-what/#findComment-251036
  • 6 months later...
Hi guys, I've got the same problem on a 00 rd690 . I've replaced the sensor and also used a piece of wire and jumped the plug but the light and buzzer continue to stay on. Today i checked the voltage to the plug and have nothing. Also what do you mean by pin a and b ? Are you speaking of each wire?
https://www.bigmacktrucks.com/topic/36180-so-now-what/#findComment-273433
I'm not up on vmac but if the shut down is like the older r mods both oil psi and coolant level will light the lamp. if ii understand the prior post the coolant sensor is a 2 wire connector one is ground the other should have 5 volts. so if you have no power you need to chase out that wire to find the problem ( busted, corroded, or shorted) if it checks out ok you would need to check the oil psi safety sw.
https://www.bigmacktrucks.com/topic/36180-so-now-what/#findComment-273437
Actually I guess I should add that I also replaced the oil pressure sensor because the other day as soon as I started it I got the code 1-1 for low oil pressure and the truck kinda went into a rough idle , so I pressed the accelerator a bit as to keep it running and it leveled out and ran fine . After that the buzzer/ lights both went off . That was the only time it ever threw code 1-1 So we replaced both sensors to be safe, but now the truck still has the code 1-7 everyday . I will check the wires again , but I see no place they could be troubled as they are wrapped in loom and then run into the bigger harness .
https://www.bigmacktrucks.com/topic/36180-so-now-what/#findComment-273440
