I am not a particularly religious fellow but I think somebody is testing me again. Old Macks are popping out of the bushes. Today's fare is two 1966 B-61s w/673 Thermodynes. One has a 5-speed triplex and the other has a "14 speed" - not sure what that is. One has been pretty well stripped the other seems quite complete and in reasonable condition. Both look like single axle tractors but pics are not clear enough. $4000 CAD for the pair. I am thinking half that might be more realistic.
A B-61 is not in my plans but thought I would let you guys know. I am picking up a crawler in the vicinity of those trucks and could collect info if someone is interested.
post-18165-0-60846600-1404177314_thumb.jpost-18165-0-24337700-1404177326_thumb.j
Best regards, Dennis
if the one has a 14 speed 72 series quadbox it'd be a good score. I've only seen one and the guy that has the trans won't part with it for reasonable money
Brian
1959 B61T
were horizontal shutters a Canadian option? first time I can remember seeing those
Good question! I did not notice but now that you mention it, I couldn't figure out why my B-30 didn't quite look like Macks I remembered from way back (when I was kid, every truck that had anything to do with heavy equipment, road building, etc, was a Mack). It is the shutters - ones I remember all had horizontal shutters. Where are the Canajun old timers?
My uncle called them blinds. Said the water and sleet would run off so the shutters so the pivot pins would still work. Said the verticals would ice up on the bottom after shut down and either hang open or closed. He ran out of Erie Pa in the 50's so take it for what its worth. Paul
ok today I found the truck owners son Tim, he runs the local saw shop I've known him for years. His son is near my age, anyhow Tim said I have a title for that truck, I sold it in 76 but never got paid for it. Long story short he said go get it and use what I can! and it does have a water retarder mounted through the drive shaft. I will post pics when I see the truck my self.
Did it or does it have the water cooling for the brakes. If it does could you snap a pic of them? Paul
If they are 1966 models, it would be a rare year. Possibly the horizontal shutters were used on the last of the B-61's. I knew of a 1966 B-61, but there were probably few built after the R model came out in 1965.
I know there is a sleeper cab B model around Syracuse Ny that has the horizontal shutters in it. not sure if its factory or not but it has them. Bob Gardineer or something maybe???? I know his last name is Gardineer. this truck has a newer top mounted Mack rear end with air ride in It also. its a single axle. it has been at the Longbranch Park Show
