How do you turn up a V pump on E9? More fuel, more power.
Remove 6 bolts of the top cover of the governer housing at the rear of the pump at the front of the opening you'll see the stop plate holder take your 1/2 inch open end and loosen the rear nut 1/2 a turn, tighten the front nut the same .put the lid on and try it! Try not to exceed 30 psi boost.
REMEMBER A candle that burns twice as bright lasts half as long! Have fun.
https://www.bigmacktrucks.com/topic/3626-ambac-v-pump/#findComment-18365
That is so true i have worked on truckes for 41 years and saw many engines burnt because some people find out how to set the fuel up but dont fully understand how to take care of the engine and the first thing you hear is this engine sure has alot of blowby and next trip you hear they scored a piston. glenn
https://www.bigmacktrucks.com/topic/3626-ambac-v-pump/#findComment-18371
