Are there seals available on the ENDT-865 engine between the front and rear manifold halves? Mine leak at the joints of the two from "wet stacking" and soaks the frame rails.
Thanks,
https://www.bigmacktrucks.com/topic/3629-exhaust-manifold-seals/
Thanks,
Your Either idling it too much or your running to cold if your getting slober at the joints.
there are no fixes that Really work well!
https://www.bigmacktrucks.com/topic/3629-exhaust-manifold-seals/#findComment-18375
I would be guilty on both counts. I don't have a trailer to pull and the engine has not done any work in about 18 years, (seriously). It has sat many seasons. I had the injectors rebuilt and it now runs very well. It is like my two cycle Detroit powered gensets when they are run unloaded, a lot of "wet stacking" takes place.
I was wondering if there was originally a packing between the manifold halves and carbon sealed the area or not.
Thanks,
https://www.bigmacktrucks.com/topic/3629-exhaust-manifold-seals/#findComment-18379
Thanks,
Rob there was never any packing just a slip joint!A piston ring affair at the turbo tubes!
https://www.bigmacktrucks.com/topic/3629-exhaust-manifold-seals/#findComment-18382
