passenger side "glove box" location. unscrew 4 screws. fuse and circuit breakers should be there. on the back side of the panel should be the location of each
https://www.bigmacktrucks.com/topic/36336-2010-pinnacle/#findComment-252685
Thanks hatcity, we're gonna check it out right away. There is no glove box, but we're gonna try to remove that panel, where it should be. The truck started to overheat, then the radio and cb went out. Do you know if there is some connection between the two?
https://www.bigmacktrucks.com/topic/36336-2010-pinnacle/#findComment-252756
The fuses are located under the triangle shaped panel in the center of the dash on top, a fuse location diagram is in the plastic bag stuck under the panel. If the diagram is missing you are looking for a 15 amp fuse in location F9. Engine overheating wont cause electrical problems just a coincidence
https://www.bigmacktrucks.com/topic/36336-2010-pinnacle/#findComment-252760
The cab fuse panel is on top of the dash in the center. The cover is held on with 3 T27 screws. Hopefully the fuse chart is still in the sleeve under the cover. Also the engine compartment fuse panel is under the drivers side below the data link connector. Also hope the fuse chart is in the sleeve on the back side of the cover also.
https://www.bigmacktrucks.com/topic/36336-2010-pinnacle/#findComment-252761
THANK YOU BOTH MACKTECK689 & WHEELER73!!! THERE IS NOT A FUSE PANEL INSIDE THE PANEL WHERE THE GLOVE BOX SHOULD BE. There is a small crack at the top of the radiator and we've been putting in just a gallon or so of water, about every 700 miles, gotta get this thing in the shop. I assume, we need to add some coolant, that should take care of that overheating problem 'til we can get this thing back to Tampa. Lots of help, thanks fellas!!!
https://www.bigmacktrucks.com/topic/36336-2010-pinnacle/#findComment-252767
  • 3 years later...
  • 2 years later...
