  • 11 months later...
can anyone tell me how to remove the piston from the power cylinder on my r600?the service manual said see ross cylinder overhaul but it has 3 bolts on the end of the cylinder????thanks adrian
Adrian Take the 3 bolts out and theres a snap ring inside you have to take out little tricky to get out should be a tiny hole in the top of cylinder to push ring down so you can pull it out. let me know if this helps.
if you break it i got two spares! :)
Grant
