The 4-5 blink code is pretty a common problem, there are several things that will cause it both electrical or mechanical. Finding the failure mode identifier is the first thing I would do, you will need to use Mack diagnostic software to determine the FMI.
https://www.bigmacktrucks.com/topic/36470-engine-code-4-5/#findComment-254095
Thanks macktech689! The trouble I'm having is it's very weak while pulling any kind of load. I'm not a mechanic by any account but it seems like it takes a few seconds for the turbo to pick up and it still isn't pulling like a 410 should. The Mack before the this one only had a 350 and it would handle the same loads like a champ.
https://www.bigmacktrucks.com/topic/36470-engine-code-4-5/#findComment-254107
