I like how the fuel tanks are behind the cab and just steps under the doors. And like a lot of west coast trailers you can see the kingpin setting is maybe 18" and you cannot move the trailer forward to cover the front duals. My Trailmobile which was a west coast is set up like that. I would seem to be more for a single axle but that was not common at all in the west.
https://www.bigmacktrucks.com/topic/36473-sweet-b71/#findComment-254146
Since I stretched mine out, I'd like to put a set of small round alum tanks behind the bunk, like that truck, and then steps(battery boxes/toolbox) under the doors. I like that look.
https://www.bigmacktrucks.com/topic/36473-sweet-b71/#findComment-254569
not sure if this is what you had in mind, but you could gather some ideas from the project notes....
http://hankstruckforum.com/htforum/index.php?PHPSESSID=dadnr4is5i3ll2t6gcn8c7gng1&topic=52765.0
yes, it's a KW but he got it to look very appealing and useable storage in the step area.
BC Mack
post-10384-0-00184300-1406853083_thumb.j
https://www.bigmacktrucks.com/topic/36473-sweet-b71/#findComment-254623
