2004 Vision.
No matter what position the knob is in air only comes out the dash vents. The temp control and fan control work fine. I'm assuming a switch or blend door problem of some sort. What's the best way to diagnose this? If it is a blend door type issue, what is the least intrusive way in to the blend door?
Done a blend door on a pickup that required removing a lot of the dash....not fun. Probably didn't need those left over screws anyway. Lol.
Thanks in advance.
https://www.bigmacktrucks.com/topic/36621-no-defrost-vision/
