Driveline vibration
Go to solution Solved by j hancock,
Truck has Mack 6 spd with a .62 overdrive. CRD 92 rears 5.73 ratio. truck has Neway susp I have been chasing this vibration for some time. I know what I should do is change tranny and rears to slow down drive shaft rpm. I have been told that I will never get rid of all the vibration due to the incredible shaft rpm. What im asking is this true? I have replaced all U joints, Slip joints. There is a little movement in output yoke in front drive. Any ideas short of better ratio and tranny?
Remember if it's got a hood it's no good!
https://www.bigmacktrucks.com/topic/36641-driveline-vibration/
drive shafts can be removed and balanced on a machine by adding or removing small weights. If the imbalance is at your cruising speed this can be mechanically harmful
so you want to make sure there is no imbalance at this speed. You may experience some imbalance at a particular rpm as you run up through the gears but this will go away as you
move on up the rpm range. You can check the bearing play in the tranny and rear end with dial indicators. Hopefully its not time for transmission bearings and hopefully you are not
missing any gear teeth.
https://www.bigmacktrucks.com/topic/36641-driveline-vibration/#findComment-255619
the drive shaft has to have phase angles set you might need to check them jump on to google theres plenty of information the one that I dont see is when you have more than on drive shaft in a row the uni's should not be in a straight line as they interfear with each other they should be set lagging behind the front shaft one tooth as you are coming back from the transmission have had this cause problems for me in the past
as to the other part of the question the drive shaft not vibrate at all no matter whats speed oh and make sure the big bolt in the gear box yoke is tight this has also caused me grief before
Paul
https://www.bigmacktrucks.com/topic/36641-driveline-vibration/#findComment-255688
Ride height has been a sore subject. I have called several folks including the people who took over Neway and received several different answers. Experimiting has been the best help.
https://www.bigmacktrucks.com/topic/36641-driveline-vibration/#findComment-256177
Paul
So are you saying the driveshaft should be one tooth off in the slip joint? Thanks for the response gentlemen
https://www.bigmacktrucks.com/topic/36641-driveline-vibration/#findComment-256179
With an engine RPM of 2100 turning an OD ratio of .62:1 , the driveshaft is turning 3387 RPM..! That's hummin'...! The Spicer document that j Hancock linked for us is an excellent read. The tailshaft centerline of the trans must be parallel to the input shaft centerline on differential. I found a vibration once because this alignment was wrong. Had to shim the carrier bearing for the fix.
"If it ain't got a motor, I ain't interested.!!"
https://www.bigmacktrucks.com/topic/36641-driveline-vibration/#findComment-256208
Im not sure what you call a slip joint Im guessing its the spline the uni crosses on each end of a section of shaft must be in alingement but on a body truck with multiple shafts they shouldnt at least that is what it said in a old work shop manual I had cant seem to find it had a look once for someone else a while ago but as you come back towards the diff as you go to each seperate shaft it should be on notch lagging behind the previous one I had this problem once the drive shaft people had all sorts of excuses as to what was causing it from engine mounts to faulty gearboxes to diff's but it had worked fine before any work was done on it so it still should work find anyway thats what I found and it worked fine since
Paul
oh yeah it got two new center bearings from them and thats when the problem started
https://www.bigmacktrucks.com/topic/36641-driveline-vibration/#findComment-256213
