Looking for a little info on turning the pump up a little on my "58" Mack, it has the END673 in it, I just want to turn it up a little to get a little more power, but not enough that it will melt a piston, or wash down the cylinders, does anyone know how to go about doing this? I have been a mechanic all my life, but have never worked on one of these, I've only had it for about two weeks, and can it be turned up higher than 2100 RPM ,or is that the highest it will safely turn? It will be used for my own personal use, and will occasionally haul a car, either on the bed, it has an 18-20' tilt bed, or on a 20' car trailer that I have. Thanks Keith
post-6848-0-80340500-1408485586_thumb.jp
https://www.bigmacktrucks.com/topic/36758-end673-pump/
Don't raise the rpm.You can add just a little rack to it.Pull the governor cover and you will understand were the rack stop is inside.The rack goes forward for more fuel but is limited by the stop.The is a screw on stop that will alow the stop to be moved forward for more rack travel.one and a half turns of the srew is enough to do damage if you don't know how to drive a hot engine.Just remember pistons and liners may not be found for that engine any more.
https://www.bigmacktrucks.com/topic/36758-end673-pump/#findComment-256645
give it one and a half turn on the rack screw and thats all you need. If you want more than that screw some more and I can tell you for sure you can get more fuel in that engine than it can handle.Old timers would set them till they could get a small red cone out of the stack and you could not do that long.
https://www.bigmacktrucks.com/topic/36758-end673-pump/#findComment-256663
Thinking of changing the differential, just needs a little taller gear, I won't be hauling any thing heavier than a car, or pickup truck, once in a great while maybe two, would like to see a little fire out of the stack at night, I remember seeing that when I was a kid riding with my dad. Before I was born he had a "51" A-Car DC100, that he went through from the ground up, and built the engine also, it had a 200 Cumins, he painted it Apache red and Sheridan blue, with real gold leaf lettering and scroll work, had "Bimbo" painted across the front bumper, because my older sister, who was only two at the time, use to go around singing that song "Bimbo Bimbo, where ya gonna goeeeeo......Bimbo Bimbo going down the roadeooooo" Lol. He had the pump set, and injectors set to where he had a little convex mirror on the passenger side aimed at the stack, she would throw a one foot flame, and he could use that mirror as a tach, he would know to downshift when that flame got down to 2" ! Lol. He swore till the day he died that that old "200" Cummins would out pull the trucks he was driving at that time, he was driving till 2000, lost him in 2003. Well.....I'm rambling....Lol
https://www.bigmacktrucks.com/topic/36758-end673-pump/#findComment-256676
  • 3 weeks later...
Well, I finally got to take it for a short drive a couple days ago, I still have the grin on my face! Lol. She drives SO MUCH BETTER than I had anticipated! There is a miss at high RPM though, could this be a weak injector, or maybe it needs the overhead run? It doesn't do it at idle, or low RPM's, just when it gets up over somewhere around 15-1600, and it doesn't sound like a dead miss, more like a weak injector. I know nothing about adjusting the injectors, or valves on these 673's, is there a website that explains it?
Thanks
Keith
https://www.bigmacktrucks.com/topic/36758-end673-pump/#findComment-259127
nasty: does it have a dynatard eng. brake? if not its the same as a gas eng. for the valve adjustments firing order the same so if the clearance is listed on the valve cover grab any automotive manual and follow the inline 6 valve adjustment procedure. if it has a dynatard some one on here I'm sure will help you out.
https://www.bigmacktrucks.com/topic/36758-end673-pump/#findComment-259182
  • 3 weeks later...
