Tonight I installed a new valve for the tractor brakes. It is the one with the blue round mushroom shaped handle on the right. It is also for tractor brakes only. The old valve did not pop out when the yellow brake release handle was pulled out and the new one does. To release the brakes on the tractor, you now have to first push the yellow knob in, then push the blue knob in. Also the new valve has a spring behind the shaft pushing the valve out when there is no air applied to it. The old one does not. There was really nothing wrong with the operation of the old one but the shaft for the knob was 1/4" in diameter, the new one is 3/8" in diameter. The only replacement knobs I could find were the 3/8" shaft size so I decided to change the valve.
Is this normal or do I have something plumbed incorrect?
Thanks,
https://www.bigmacktrucks.com/topic/3687-air-valve/
Thanks,
The valve is wired up right i have seen them both ways but i do not know which way dot wants it to work but it will work ok like that.
https://www.bigmacktrucks.com/topic/3687-air-valve/#findComment-18690
Sounds right to me. Before the single manifold valves you coulden't charge the trailer brakes while the yellow tractor valve was out. So they put a third blue valve between the yellow and the tractor spring brakes so you could push the yellow knob in which allows the red knob to be pushed in. Then you just keep the blue valve out to keep the tractor parked while you charge the trailer or hook whatever to the emergency/supply line. Then to park the whole lot just pull the yellow which should cause the red and blue to pop back out.
-Thad
https://www.bigmacktrucks.com/topic/3687-air-valve/#findComment-18691
Thanks guys, it works well, just different. I'm getting ready to put it on the road next month and want everything working right.
https://www.bigmacktrucks.com/topic/3687-air-valve/#findComment-18697
