Hey guys i have a 02 ch613 front differential had went out so i bought another one but without the power divider air connection put it back together and i can drive about 20 miles good then the truck starts to make a noise and when i pull over and drive again it goes away until another 20 miles they said i need driveline work because i had to pull out my drive shaft 2 inches for the new differential could that be the cause im not sure what to do has anybody else had that problem please help
https://www.bigmacktrucks.com/topic/36918-drive-line-or-not/
  • 2 months later...
  On 11/26/2014 at 10:45 AM, scottwetzel said:
I'm having the exact problem!!! I just replaced my tires on my front rear but not the back one. I think the power divider is trying to engage. Did u fix this problem?
If the tires are a different diamator your going to have a problem,move two of the new tires to to the rear axle opposit side and see what happens.
https://www.bigmacktrucks.com/topic/36918-drive-line-or-not/#findComment-268220
