A bar puller is all you need to get the hub off. When you put the hub back on heat it in a deep fryer to 400 degrees. Have welding gloves handy and slide hub on quickly and install bolt right away to seat hub. If you pound the hub on you will mess up the crankshaft thrust washers.. Steve
https://www.bigmacktrucks.com/topic/37202-front-seal/#findComment-261330
