I got my truck insured and tagged yesterday, and I drove it to work yesterday and today, on the way in to my shop this morning I thought the transmission sounded a little low on lube. I checked it and it was definitely low, I could reach it with my finger, but had to really reach to do it. The whole driver side of the trans was wet with lube, and it appears to be coming from the top of the transmission, what would be leaking up there? Is there a vent that could be clogged? This thing sat for two years (mud daubers?) or is this something that happens with B models, a common leak area on top of the trans? Love the truck! I want to drive it EVERYWHERE !! Lol
https://www.bigmacktrucks.com/topic/37291-trans-leak/
You mentioned it was up high. Keep an eye on the PTO covers also. I had one that rotted through and developed a small drip. Had to drain it and replace it with new cover.
https://www.bigmacktrucks.com/topic/37291-trans-leak/#findComment-262582
Well! Both shifter towers were loose! All four bolts on the auxiliary tower were VERY loose, and two bolts on the Main tower were loose. THANKS Everyone ! I pressure washed the trans down,now I'll keep an eye on it and see.......................
https://www.bigmacktrucks.com/topic/37291-trans-leak/#findComment-262595
