I was wondering when this was going to get posted. At first I thought HOLY SHIT thats my old trailer. Upon further review not my old equipment. Taylor Trucklines in Mn. they just got into HH from what I heard. Think there hh days are over
was wondering if this was why you sold the truck,lol
Today's RR crossings have computer circuits that will judge the speed of a train . Just throwing a pipe across the rails won't gt crossing gates to lower or a signal to drop to red. You would have to find the isolated sections of rail and short them all to fool the signal system computer into thinking a tran had passed. Todays signal systems are complex and they are built to avoid faulty signals and train location reporting....laying a pipe across May have worked 30 years ago but not in today's world.
Hate to break it to ya but they arent all new, we (CSX) just replaced part (not all) of the original signal system from the 1940's and 50's from the Chattanooga Subdivision. It would never have been replaced but it wouldnt work with govt mandated PTC so one section at a time its getting swapped out, but its still just a track shunt to start the grade crossing system , its more intuitive but you can still fool it with wire and a resistor.
I am not a train man, but How Long does it take to stop a train?? From the number of cars which crossed the highway after impact it does not look like the engineer ever applied the brakes??? And the tank cars which derailed well beyond the crossing finally stopped it??
Brocky
I don't know anything about trains either, but I used to know a guy that worked for the railroad and remember him saying they started putting on the brakes 2 miles from their stop. I don't know how fast they were going in the first place though, or how long the train was.
Unrelated, but a B model Mack-
http://www.youtube.com/watch?v=vMEOOWsNROo
Train braking is terrain and condition Dependant, a decent rule of thumb is a 100car train on level track takes 1 mile from 50mph, if its down hill or wet or cold double the distance. The changes don't end there, most mixed consist trains average half loads half empties, coal, grain and tank trains are most always all loaded or all empty so again double the stopping distance. If there was a curve or building back up the track restricting vision of the truck the brakes may not have been activated till a couple hundred feet before the truck.
So, a hunnert car bananner train in Mississippi where it's all flat would mean the engineer spotted Marcel from about a mile away...sounds legit to me.
any body notice it looks like half the mud guard or fender or wing or what ever you yanks call it is missing
Paul
84
Thanks for the explaination.. That helps me understand the situation better. If you have to release the brakes to recharge the system then how do you hold back a train on a long downhill like Cajon pass beside I-15 coming down int the LA area?? Are the engines able to do it like a truck with a Jake??
Brocky
Brocky
Dynamic braking is used downhill where the electric power motors are used as generators and either recharge the system or release the electricity through brake grid resistors located in the locomotive to the atmosphere via heat.
There was an axle electromagnetic retarder made in Spain by Ilasa used on truck trailers that could do the same thing coming down a hill. Not sure if they are still around.
Jim and Ron
Thank you.. Just had to get my head screwed on right this morning.
I now remember hearing about the generator type retarders out west.. I think the only one I ever saw was at the 2003 ATHS Syracuse show. Some one from Calif had a souped up supercharger Cummins engine mounted on a blue trailer and used one of those retarders to put a load on it. Straight pipe and it "TALKED"!!!
Brocky
Some trains that traverse steep grades use engines connected to the rear as "pushers" and "brakes". See this often on the Horseshoe Curve near Altoona, PA.
Ken
For long downgrades the locomotive's will go into dynamic brake mode and the engineer will make a brake set and if needed make another set but once you start you need to be pretty sure of where you are going and what your doing. We have a helper district in Cowan Tn, they have been living trains over the mountain there since the early 1900's, most trains need help up but hold their own down so the helpers cut off on the move when the lead locomotive crests the grade (which is in the middle of one of the oldest tunnels too) look up Cowan Tn pusher and Cowan Tn tunnel.
