Replace Clutch Cable Superliner E9
Royal Glen
Remove the top cover on the dash over the speedometer/ tachometer instrument cluster and work from above. You may have to remove the speedometer and tachometer cable to get enough clearance. There is a clevis, pin and cotter pin.
Remove those three and with the clevis unscrewed you can slide the cable out thru the boot.
Even from above you will need long fingers, small hands or both.
