Hello,
Great site.
I've been reading for a a few days and done searchs, found lots of good info....
I'm helping to get running a 1948 mack fire truck.. engine is ( EN330G- etc.)
I'm looking for the valve clarence information both cold and hot setting???
I'm also looking for timing spec's my books just don't go old enough...
Thanks much,
1948mack :mack1:
https://www.bigmacktrucks.com/topic/3741-engine-timing-and-valve-specs/
Congradulations on the fire truck save.
I've got a 1945 EG with the EN330 engine, so I should have some info around the office here someplace. I'll check the books tonite and see whot I can come up with.
Keep an eye out for a Motor's Repair Manual. They're getting scarce and fetching a big buck, too.
I'll let you know what I find out.
jim (mass)
righto here we go
engine model: EN330
Firing order: 153624
Spark plug gap: .025"
Timing mark:5 degree's BTC (mark located on Fltwheel)
Cylinder head torque: 95-100 lb.ft
Valve seat angle: 30 degree's
Valve clearance-HOT-: Intake .017"
" " " " " " " " " " " " " : Exhaust .017 (note: no cold setting's)
Valve spring pressure: 48lb @ 2.75"
That help at all ??? ?? ??? I have more spec's here infront of me if needed like general electrical piston sizes etc. even have how to instruction's
Edited by werkhorse
I would like to say, thanks for all the replies.. :mack1:
Today, We should get it running again. this time with out the miss, due too stuck valve..
While it was torn down we change oil pan gasket, & did the top end of course...
Did all The Brakes, wheel cyl and grease seals last month..
That was a chore finding replacement brake's, got it done though..
Thanks again,
1948mack
