Preferences
Preferencwe
we're getting a 30k rear axle for our 6 wheel dump. it currently has 22.5 rubber, 6 speed low hole tranny, 250 motor and differential ratio of 4.00. it tops out at about 62 mph at 2100 rpms. i can get this axle with either a 3.90 or a 4.10. it often pulls a 20 ton tag. will the 3.90 add more speed and if so how much? how much lower end power will we lose? the only thing im worried about with the 4.10 is it will be to slow. i know either ratio is only a 10th higher or lower than what we have. i just want to know which would be best. the axle is complete and our 22.5 wheels will fit.
Preferences
1
2
3
4
5
6
7
8
9
0
Backspace
Tab
q
w
e
r
t
y
u
i
o
p
Return
capslock
a
s
d
f
g
h
j
k
l
shift
z
x
c
v
b
n
m
shift
English
Deutsch
Español
Français
Italiano
Português
Русский
alt
alt
Preferences
https://www.bigmacktrucks.com/topic/37440-390-or-410-gear-ratio/
If you have current figures just make a proportion. Divide the "new" ratio by the current, than multiply you curren top speed with the result.
So will see the increase or decrease.
If you prefere sharp figures you need to count out your wheel's one rev length (3.14xOD), and being known how many revs the engine does (2100 per MINUTE) you continue dividing them by overall drivetrain ratio (0.60 overdrive in T2060 tranny multiplied with 4.00 in rears). After dividing 2100/(0.60x4.0) = 875 you get the number of revs of the wheel per minute (875). Than knowing how long way your wheel makes by every revolution (don't know what 22.5's they are) you multiply it with 875 and get the way the truck makes in one MINUTE. Than divide it by 60 and see the way in one hour. But... If you count the wheel's circle length in inches you will get the speed in INCHES per hour. So you'll need to divide it by the number of inches in a mile to see the top speed by common way. Sorry I'm not ready to tell you how many inches in a mile is, I'm used to live in the metric world :)
